Zum Hauptinhalt wechseln
Toshiba Satellite L675D-S7016 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite L675D-S7016 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 Keyboard Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite L675D-S7016 Keyboard Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite L675D-S7016 Keyboard Replacement: Schritt 3, Bild 3 von 3
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Toshiba Satellite L675D-S7016 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 3 Toshiba Satellite L675D-S7016 Keyboard Replacement, Keyboard: Schritt 4, Bild 2 von 3 Toshiba Satellite L675D-S7016 Keyboard Replacement, Keyboard: Schritt 4, Bild 3 von 3
    • Pry under the plastic strip, starting on the top right side of the key board with a Heavy Duty Spudger.
    • Once the first corner is raised, use your hand pulling upwards and release the rest of the strip.
  5. Toshiba Satellite L675D-S7016 Keyboard Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite L675D-S7016 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the first 3mm screw with the Phillips #1 screwdriver.
    • Remove the next three 3mm screws.
  6. Toshiba Satellite L675D-S7016 Keyboard Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite L675D-S7016 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Lift the keyboard gently . Slide it forward towards the screen and speakers. This reveals the connection needed for the next step.
  7. Toshiba Satellite L675D-S7016 Keyboard Replacement: Schritt 7, Bild 1 von 3 Toshiba Satellite L675D-S7016 Keyboard Replacement: Schritt 7, Bild 2 von 3 Toshiba Satellite L675D-S7016 Keyboard Replacement: Schritt 7, Bild 3 von 3
    • Use the pointed end of the Heavy-Duty Spudger and push the pins toward the screen, leaving them in this position.
    • Carefully slide the connector out of the port.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Austin Bons
1.131 Reputation
8 Anleitungen geschrieben
UC Davis, Team 2-2, Oliver Fall 2016 Mitglied von UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 782
