Zum Hauptinhalt wechseln
Toshiba Satellite L675D-S7016 RAM Replacement
Was du brauchst
  1. Toshiba Satellite L675D-S7016 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 RAM Replacement: Schritt 2, Bild 1 von 1
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 RAM Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite L675D-S7016 RAM Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite L675D-S7016 RAM Replacement: Schritt 3, Bild 3 von 3
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Toshiba Satellite L675D-S7016 RAM Replacement, Back Panel Removal: Schritt 4, Bild 1 von 1
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  5. Toshiba Satellite L675D-S7016 RAM Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite L675D-S7016 RAM Replacement: Schritt 5, Bild 2 von 2
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
  6. Toshiba Satellite L675D-S7016 RAM Replacement, RAM: Schritt 6, Bild 1 von 3 Toshiba Satellite L675D-S7016 RAM Replacement, RAM: Schritt 6, Bild 2 von 3 Toshiba Satellite L675D-S7016 RAM Replacement, RAM: Schritt 6, Bild 3 von 3
    • Using your fingers, spread the spring tabs holding the top stick of RAM in place.
    • Once the tabs are spread apart, the stick of RAM will pop up.
    • Remove the first stick of RAM by pulling out along the same angle the RAM stick springs up.
  7. Toshiba Satellite L675D-S7016 RAM Replacement: Schritt 7, Bild 1 von 3 Toshiba Satellite L675D-S7016 RAM Replacement: Schritt 7, Bild 2 von 3 Toshiba Satellite L675D-S7016 RAM Replacement: Schritt 7, Bild 3 von 3
    • Repeat the same procedure to remove the second stick of RAM.
Abschluss
Austin Bons
1.131 Reputation
8 Anleitungen geschrieben
UC Davis, Team 2-2, Oliver Fall 2016 Mitglied von UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 588
