Einleitung
If you determined that the LCD screen is unresponsive, or "black," this guide will show you how to access and remove the screen.
Was du brauchst
Flip the laptop upside down. Locate the two latches on both sides of the battery.
Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
Simultaneously slide the latch on the left outwards while pulling the battery towards you.
Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
Work your way around the border of the panel, releasing the rest of the clips.
Once all clips are released, lift the cover up and pull towards you.
Slide the hard drive to the left, using the silver tab.
Pull up the silver tab, removing the hard drive from the slot.
Using your fingers, spread the spring tabs holding the top stick of RAM in place.
Once the tabs are spread apart, the stick of RAM will pop up.
Remove the first stick of RAM by pulling out along the same angle the RAM stick springs up.
In diesem Schritt verwendetes Werkzeug:Heavy-Duty Spudger$4.99
Pry under the plastic strip, starting on the top right side of the key board with a Heavy Duty Spudger.
Once the first corner is raised, use your hand pulling upwards and release the rest of the strip.
Remove the first 3mm screw with the Phillips #1 screwdriver.
Remove the next three 3mm screws.
Use the pointed end of the Heavy-Duty Spudger and push the pins toward the screen, leaving them in this position.
Carefully slide the connector out of the port.
Remove the following screws with a Phillips #1 screwdriver.
Seventeen 5mm screws (recessed)
Three 2mm screws in the battery bay (flush-mounted)
Single 5mm screw does not need removal unless working on the screen
Pry under the top case housing along the perimeter with a plastic opening tool.
Slide the metal power button connector out of its port, allowing the black wire to be moved from under it.
The screen is attached with two hinges on both sides of the laptop.
Remove the three 5mm screws (two on the left hinge, one on the right hinge) using a screwdriver.
Remove brass fitting held in place by removing the 5mm screw circled in yellow in step 15.
Remove the 6 rubber tabs on the housing using a metal Spudger.
Remove the six 6mm screws holding the housing.
Remove two 5mm screws using a screwdriver. There is one screw at each hinge.
Remove white wire from the perimeter of the plastic housing.
Remove the three 2.5mm screws on each side of the screen casing with a screwdriver.
The two metal casings can now be removed.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
