Zum Hauptinhalt wechseln
Toshiba Satellite L675D-S7016 Top Case Housing Removal
Was du brauchst
  1. Toshiba Satellite L675D-S7016 Top Case Housing Removal, Battery: Schritt 1, Bild 1 von 1
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 Top Case Housing Removal: Schritt 2, Bild 1 von 1
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 Top Case Housing Removal: Schritt 3, Bild 1 von 3 Toshiba Satellite L675D-S7016 Top Case Housing Removal: Schritt 3, Bild 2 von 3 Toshiba Satellite L675D-S7016 Top Case Housing Removal: Schritt 3, Bild 3 von 3
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Toshiba Satellite L675D-S7016 Top Case Housing Removal, Back Panel Removal: Schritt 4, Bild 1 von 1
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  5. Toshiba Satellite L675D-S7016 Top Case Housing Removal: Schritt 5, Bild 1 von 2 Toshiba Satellite L675D-S7016 Top Case Housing Removal: Schritt 5, Bild 2 von 2
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
  6. Toshiba Satellite L675D-S7016 Top Case Housing Removal, Hard Drive: Schritt 6, Bild 1 von 2 Toshiba Satellite L675D-S7016 Top Case Housing Removal, Hard Drive: Schritt 6, Bild 2 von 2
    • Slide the hard drive to the left, using the silver tab.
    • Pull up the silver tab, removing the hard drive from the slot.
    • Do not touch the metal data pins on the hard drive or computer.
  7. Toshiba Satellite L675D-S7016 Top Case Housing Removal, Keyboard: Schritt 7, Bild 1 von 3 Toshiba Satellite L675D-S7016 Top Case Housing Removal, Keyboard: Schritt 7, Bild 2 von 3 Toshiba Satellite L675D-S7016 Top Case Housing Removal, Keyboard: Schritt 7, Bild 3 von 3
    • Pry under the plastic strip, starting on the top right side of the key board with a Heavy Duty Spudger.
    • Once the first corner is raised, use your hand pulling upwards and release the rest of the strip.
  8. Toshiba Satellite L675D-S7016 Top Case Housing Removal: Schritt 8, Bild 1 von 2 Toshiba Satellite L675D-S7016 Top Case Housing Removal: Schritt 8, Bild 2 von 2
    • Remove the first 3mm screw with the Phillips #1 screwdriver.
    • Remove the next three 3mm screws.
  9. Toshiba Satellite L675D-S7016 Top Case Housing Removal: Schritt 9, Bild 1 von 2 Toshiba Satellite L675D-S7016 Top Case Housing Removal: Schritt 9, Bild 2 von 2
    • Lift the keyboard gently . Slide it forward towards the screen and speakers. This reveals the connection needed for the next step.
  10. Toshiba Satellite L675D-S7016 Top Case Housing Removal: Schritt 10, Bild 1 von 3 Toshiba Satellite L675D-S7016 Top Case Housing Removal: Schritt 10, Bild 2 von 3 Toshiba Satellite L675D-S7016 Top Case Housing Removal: Schritt 10, Bild 3 von 3
    • Use the pointed end of the Heavy-Duty Spudger and push the pins toward the screen, leaving them in this position.
    • Carefully slide the connector out of the port.
  11. Toshiba Satellite L675D-S7016 Top Case Housing Removal, Top Case Housing: Schritt 11, Bild 1 von 1
    • Remove the following screws with a Phillips #1 screwdriver.
    • Seventeen 5mm screws (recessed)
    • Three 2mm screws in the battery bay (flush-mounted)
    • Single 5mm screw does not need removal unless working on the screen
  12. Toshiba Satellite L675D-S7016 Top Case Housing Removal: Schritt 12, Bild 1 von 2 Toshiba Satellite L675D-S7016 Top Case Housing Removal: Schritt 12, Bild 2 von 2
    • Remove five 5mm screws with the screwdriver.
  13. Toshiba Satellite L675D-S7016 Top Case Housing Removal: Schritt 13, Bild 1 von 2 Toshiba Satellite L675D-S7016 Top Case Housing Removal: Schritt 13, Bild 2 von 2
    • Locate the trackpad connector.
    • Pull the ribbon from the connector.
  14. Toshiba Satellite L675D-S7016 Top Case Housing Removal: Schritt 14, Bild 1 von 2 Toshiba Satellite L675D-S7016 Top Case Housing Removal: Schritt 14, Bild 2 von 2
    • Pry under the top case housing along the perimeter with a plastic opening tool.
    • Be careful and gentle with this step, the clips you are releasing here are plastic and can be broken by violent prying.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Austin Bons
1.131 Reputation
8 Anleitungen geschrieben
UC Davis, Team 2-2, Oliver Fall 2016 Mitglied von UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Great help this tutorial helped
Susan Scroggs - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 1,109
