Zum Hauptinhalt wechseln
Toshiba Satellite L755-S5244 RAM Replacement
Was du brauchst
  1. Toshiba Satellite L755-S5244 RAM Replacement, RAM: Schritt 1, Bild 1 von 2 Toshiba Satellite L755-S5244 RAM Replacement, RAM: Schritt 1, Bild 2 von 2
    • Loosen the two 3mm Phillips #0 screws securing the hard drive panel. The panel will retain the screws, so do not remove them completely.
    • Remove the panel from the laptop (the hard drive does not need to be removed).
  2. Toshiba Satellite L755-S5244 RAM Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite L755-S5244 RAM Replacement: Schritt 2, Bild 2 von 2
    • Loosen the three 3mm Phillips #0 screws that secure the center panel. The screws are retained by the cover, so do not remove them completely.
    • Remove the panel by pulling out to the right.
    • The two RAM sticks are stacked, one on top of the other.
  3. Toshiba Satellite L755-S5244 RAM Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite L755-S5244 RAM Replacement: Schritt 3, Bild 2 von 2
    • Each RAM stick has two (2) snap locks, one on each end. In the image the bottom snap is obscured by the cable.
  4. Toshiba Satellite L755-S5244 RAM Replacement: Schritt 4, Bild 1 von 1
    • Move the retaining clips out of their locking position, allowing the RAM stick to pop up.
    • Lift the free end of the RAM stick until the stick can be freely removed from its slot.
  5. Toshiba Satellite L755-S5244 RAM Replacement: Schritt 5, Bild 1 von 1
    • The RAM stick has a notch that is not centered on the stick. Be sure to take note of the RAM stick's orientation for reinstallation
  6. Toshiba Satellite L755-S5244 RAM Replacement: Schritt 6, Bild 1 von 1
    • Repeat for the second RAM stick.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 15
Insgesamt: 331
