Zum Hauptinhalt wechseln
Toshiba Satellite L755D-S5150 Battery Removal
  1. Toshiba Satellite L755D-S5150 Battery Removal, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite L755D-S5150 Battery Removal, Battery: Schritt 1, Bild 2 von 2
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Kyler Clonts
258 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 2-5, Sullivan Fall 2016 Mitglied von USF Tampa, Team 2-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G5
4 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
I've got a trouble when I try to charge the battery, when I plug in the power supply charger at the laptop it is lit led one and three in the front panel, that is OK, but after a few seconds all leds blinking and the charge is breaking on the screen appear no battery plug in. I replaced the battery pack for a new one, but the trouble continuos……
Iván Andrade - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 220
