Zum Hauptinhalt wechseln
Toshiba Satellite L775D-S7340 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite L775D-S7340 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the laptop is unplugged and powered off.
    • Locate the battery latches on the underside of the laptop.
  2. Toshiba Satellite L775D-S7340 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Slide the right latch to the right until you hear it lock into place.
    • Slide the left latch to the left and hold it.
  3. Toshiba Satellite L775D-S7340 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Slide the battery out towards you.
  4. Toshiba Satellite L775D-S7340 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 1
    • Pry up the thin narrow strip of facing above the keyboard using the opening tool.
  5. Toshiba Satellite L775D-S7340 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the four screws securing the keyboard using the T4 Torx screwdriver,
  6. Toshiba Satellite L775D-S7340 Keyboard Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite L775D-S7340 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Lift the keyboard slowly using the opening tool and lean it toward touchpad.
    • It will still be held by the connector ribbon. Make sure not to pull out the connector ribbon.
  7. Toshiba Satellite L775D-S7340 Keyboard Replacement: Schritt 7, Bild 1 von 1
    • The ribbon is attached by a white clip. Wedge the white clip up carefully using the spudger. This will release the connector ribbon and you can now remove the keyboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Madeline Park
441 Reputation
4 Anleitungen geschrieben
Washington State, Team S4-G120, Phelps-Hillen Fall 2017 Mitglied von Washington State, Team S4-G120, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S4G120
6 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
I need to know how to change a plasma for a Toshiba Satellite L775D-S7340
Cyndi May Evans - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 1,711
