Zum Hauptinhalt wechseln
Toshiba Satellite L855-S5119 Charger Port Replacement
Was du brauchst
  1. Toshiba Satellite L855-S5119 Charger Port Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop face down to expose the back.
    • Locate the battery.
  2. Toshiba Satellite L855-S5119 Charger Port Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite L855-S5119 Charger Port Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite L855-S5119 Charger Port Replacement: Schritt 2, Bild 3 von 3
    • Locate the battery latches. The battery latch mechanism can be compared to a door -- The right latch, when pushed right, unlocks the battery, while the left latch, when pushed left, releases the battery, pushing it out from its container.
    • Push the latch on the right to the right to unlock the battery latch locking mechanism.
    • Push the battery latch on the left to the left to unlock the battery.
  3. Toshiba Satellite L855-S5119 Charger Port Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite L855-S5119 Charger Port Replacement: Schritt 3, Bild 2 von 2
    • With the left battery latch pushed left, remove the battery from its port by lifting the battery from the middle of the battery.
    • The battery will come free.
  4. Toshiba Satellite L855-S5119 Charger Port Replacement, Back Plate Removal: Schritt 4, Bild 1 von 3 Toshiba Satellite L855-S5119 Charger Port Replacement, Back Plate Removal: Schritt 4, Bild 2 von 3 Toshiba Satellite L855-S5119 Charger Port Replacement, Back Plate Removal: Schritt 4, Bild 3 von 3
    • Turn the laptop over to place it top down.
    • Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
    • Lift the back plate off the laptop, exposing the RAM and Hard Disk.
  5. Toshiba Satellite L855-S5119 Charger Port Replacement, Optical Drive: Schritt 5, Bild 1 von 2 Toshiba Satellite L855-S5119 Charger Port Replacement, Optical Drive: Schritt 5, Bild 2 von 2
    • Using a Phillips #0 screwdriver, remove the single 3mm screw.
  6. Toshiba Satellite L855-S5119 Charger Port Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite L855-S5119 Charger Port Replacement: Schritt 6, Bild 2 von 2
    • Rotate the laptop so that you have access to the optical drive.
    • The optical drive is now only attached by a port in the drive's back. The optical drive can be pulled straight out of its housing.
    • Remove the drive.
  7. Toshiba Satellite L855-S5119 Charger Port Replacement, Hard Drive: Schritt 7, Bild 1 von 2 Toshiba Satellite L855-S5119 Charger Port Replacement, Hard Drive: Schritt 7, Bild 2 von 2
    • Unscrew the hard drive.
    • There could be up to five 3mm screws - One on each corner of the hard drive, and one at one end of the hard drive, attaching the drive to the laptop's frame.
    • Carefully push the hard drive away from its port. This should not require substantial force.
    • Lift the hard drive out.
    • Some hard drives have a plastic tab, which can be lifted from to remove the hard drive.
    • Otherwise, take hold of opposite sides of the hard drive and lift the drive straight up.
  8. Toshiba Satellite L855-S5119 Charger Port Replacement, Back Cover Removal: Schritt 8, Bild 1 von 2 Toshiba Satellite L855-S5119 Charger Port Replacement, Back Cover Removal: Schritt 8, Bild 2 von 2
    • Unscrew the screws circled in red. This includes eleven 6mm screws, and one 5mm screw underneath where the optical drive was housed. All screws can be removed with a Phillips #0 screwdriver.
    • Carefully remove the back cover. The battery holder contains notches that help hold the case in place, so take care not to break those.
  9. Toshiba Satellite L855-S5119 Charger Port Replacement, Charger Port: Schritt 9, Bild 1 von 2 Toshiba Satellite L855-S5119 Charger Port Replacement, Charger Port: Schritt 9, Bild 2 von 2
    • Locate the DC power port. Note the 4-pin connector attaching the port to the motherboard.
  10. Toshiba Satellite L855-S5119 Charger Port Replacement: Schritt 10, Bild 1 von 2 Toshiba Satellite L855-S5119 Charger Port Replacement: Schritt 10, Bild 2 von 2
    • Remove the 4 pin female connector from the male connector attached to the motherboard.
    • Lift the DC power port from the bracket holding it in place.
    • There are black plastic housings for the wires, holding the wires in position. Remove the red and black wires connecting the DC Port to the 4-pin power connector from underneath the black plastic housings.
    • Remove the DC Power port and 4 pin connector.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Tyler Shafer
426 Reputation
3 Anleitungen geschrieben
Washington State, Team S1-G5, Lobnitz Spring 2018 Mitglied von Washington State, Team S1-G5, Lobnitz Spring 2018
WSU-LOBNITZ-S18S1G5
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 18
Insgesamt: 938
