Zum Hauptinhalt wechseln
Toshiba Satellite L855-S5119 Random Access Memory Replacement
Was du brauchst
  1. Toshiba Satellite L855-S5119 Random Access Memory Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop face down to expose the back.
    • Locate the battery.
  2. Toshiba Satellite L855-S5119 Random Access Memory Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite L855-S5119 Random Access Memory Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite L855-S5119 Random Access Memory Replacement: Schritt 2, Bild 3 von 3
    • Locate the battery latches. The battery latch mechanism can be compared to a door -- The right latch, when pushed right, unlocks the battery, while the left latch, when pushed left, releases the battery, pushing it out from its container.
    • Push the latch on the right to the right to unlock the battery latch locking mechanism.
    • Push the battery latch on the left to the left to unlock the battery.
  3. Toshiba Satellite L855-S5119 Random Access Memory Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite L855-S5119 Random Access Memory Replacement: Schritt 3, Bild 2 von 2
    • With the left battery latch pushed left, remove the battery from its port by lifting the battery from the middle of the battery.
    • The battery will come free.
  4. Toshiba Satellite L855-S5119 Random Access Memory Replacement, Back Plate Removal: Schritt 4, Bild 1 von 3 Toshiba Satellite L855-S5119 Random Access Memory Replacement, Back Plate Removal: Schritt 4, Bild 2 von 3 Toshiba Satellite L855-S5119 Random Access Memory Replacement, Back Plate Removal: Schritt 4, Bild 3 von 3
    • Turn the laptop over to place it top down.
    • Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
    • Lift the back plate off the laptop, exposing the RAM and Hard Disk.
  5. Toshiba Satellite L855-S5119 Random Access Memory Replacement, Random Access Memory: Schritt 5, Bild 1 von 1
    • Locate the Random Access Memory.
  6. Toshiba Satellite L855-S5119 Random Access Memory Replacement: Schritt 6, Bild 1 von 3 Toshiba Satellite L855-S5119 Random Access Memory Replacement: Schritt 6, Bild 2 von 3 Toshiba Satellite L855-S5119 Random Access Memory Replacement: Schritt 6, Bild 3 von 3
    • Pull back the two retention clips holding the RAM in place allowing it to pop up.
    • Remove the RAM by pulling it from the SO-DIMM slot.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Washington State, Team S1-G5, Lobnitz Spring 2018 Mitglied von Washington State, Team S1-G5, Lobnitz Spring 2018
WSU-LOBNITZ-S18S1G5
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 407
