Einleitung
If your computer runs more slowly than it used to, your random access memory (RAM) chip may need replacement. Use this guide to replace your RAM.
Was du brauchst
Locate the RAM card at the top left corner closest to the bottom of the battery.
Using two fingers, push the two levers outwards in opposite directions of each other to release the RAM card.
Remove the existing RAM card and insert the your new RAM by snapping the RAM in place. Make sure the notch on your RAM card matches up with the slot.
