Was du brauchst
Insert the plastic opening tool above the F1 key.
Apply upward pressure until the black plastic strip snaps off. The entire strip will easily come off from left to right.
Find the screws above the F1 and INS keys.
Unscrew both screws with a Phillips #0 screwdriver.
Slowly lift the top edge of the keyboard out with your fingers.
The ribbon cable located on the back of the keyboard will become accessible.
Locate the black ribbon cable flap.
Detach flap with plastic opening tool. The ribbon cable will become free.
Remove the back panel by removing the three labeled screws with a Phillips #0 screwdriver.
Remove the circled screws with Phillips #0 screwdriver.
Remove these screws from the underside of the laptop with Phillips #0 screwdriver.
Disconnect the three circled antennas by lightly pulling upward with your fingers. They should detach easily.
Note: Yours may only have two (2) antennas. Pay attention to the Orientation of the Aluminum bracket with the pads for reinstallation.
Remove the top plastic cover by lifting upward from the bottom left-hand corner as shown. The cover will come off easily.
Remove the circled motherboard screws with a Phillips #0 Scewdriver.
Disconnect this ribbon cable.
Remove the motherboard from the left side by gently lifting the left side upward.
Locate the 3 circled clips holding the fan to the motherboard.
Pry each clip outward while applying upward force on the fan as shown.
Carefully pull out the fan.
Optionally you may clean the fan with Air + Q-Tips. To remove the blade turn the fan over and gently pull the fan blade from the housing.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
