Zum Hauptinhalt wechseln
Toshiba Satellite M305D-S4829 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite M305D-S4829 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Unlatch the battery by pushing outward on both latches.
  2. Toshiba Satellite M305D-S4829 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Slide battery out.
  3. Toshiba Satellite M305D-S4829 Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 1
    • Remove the five "F2" screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite M305D-S4829 Keyboard Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite M305D-S4829 Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Insert the plastic opening tool above the F1 key.
    • Apply upward pressure until the black plastic strip snaps off. The entire strip will easily come off from left to right.
  5. Toshiba Satellite M305D-S4829 Keyboard Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite M305D-S4829 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Find the screws above the F1 and INS keys.
    • Unscrew both screws with a Phillips #0 screwdriver.
  6. Toshiba Satellite M305D-S4829 Keyboard Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite M305D-S4829 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Slowly lift the top edge of the keyboard out with your fingers.
    • The ribbon cable located on the back of the keyboard will become accessible.
  7. Toshiba Satellite M305D-S4829 Keyboard Replacement: Schritt 7, Bild 1 von 2 Toshiba Satellite M305D-S4829 Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Locate the black ribbon cable flap.
    • Detach flap with plastic opening tool. The ribbon cable will become free.
  8. Toshiba Satellite M305D-S4829 Keyboard Replacement: Schritt 8, Bild 1 von 1
    • Your keyboard has now been successfully removed.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 4-3, Regan Spring 2011 Mitglied von Cal Poly, Team 4-3, Regan Spring 2011
CPSU-REGAN-S11S4G3
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 4,561
