Zum Hauptinhalt wechseln
Toshiba Satellite M35X-S114 Hard Drive Replacement
Was du brauchst
  1. Toshiba Satellite M35X-S114 Hard Drive Replacement, Unlock the Battery from its Compartment: Schritt 1, Bild 1 von 2 Toshiba Satellite M35X-S114 Hard Drive Replacement, Unlock the Battery from its Compartment: Schritt 1, Bild 2 von 2
    • Locate the battery near the bottom left-hand side of the device.
    • Locate the two switches above the battery's top left corner.
    • Use any finger to move the smaller switch above the battery to the unlock position.
    • A small icon of a padlock will identify the "lock" and "unlock" positions of the switch.
  2. Toshiba Satellite M35X-S114 Hard Drive Replacement, Move the Battery's Release Switch: Schritt 2, Bild 1 von 2 Toshiba Satellite M35X-S114 Hard Drive Replacement, Move the Battery's Release Switch: Schritt 2, Bild 2 von 2
    • Use any finger to move the larger switch above the battery to the left and hold the switch.
  3. Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Battery: Schritt 3, Bild 1 von 2 Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Battery: Schritt 3, Bild 2 von 2
    • Place your fingernail or fingertip into the groove near the top right of the battery.
    • Pull the battery out with your finger. Release the larger switch once the battery is out.
  4. Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Hard Drive screw: Schritt 4, Bild 1 von 3 Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Hard Drive screw: Schritt 4, Bild 2 von 3 Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Hard Drive screw: Schritt 4, Bild 3 von 3
    • Locate the Hard Drive.
    • Locate the screw near the Hard Drive.
    • Use a Phillips 00 screwdriver to remove the 7.50mm screw.
  5. Toshiba Satellite M35X-S114 Hard Drive Replacement, Slide the Hard Drive out: Schritt 5, Bild 1 von 2 Toshiba Satellite M35X-S114 Hard Drive Replacement, Slide the Hard Drive out: Schritt 5, Bild 2 von 2
    • Please note that the hard drive from the laptop used is missing.
    • Slide the hard drive out.
    • The hard drive may not slide out easily, and may require a little bit of force in order to be disconnected from the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
CSU Fullerton, Team 2-4, Bruce Fall 2014 Mitglied von CSU Fullerton, Team 2-4, Bruce Fall 2014
CSUF-BRUCE-F14S2G4
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 1,745
