Zum Hauptinhalt wechseln
Toshiba Satellite M45 Display Replacement
Was du brauchst
  1. Toshiba Satellite M45 Display Replacement, Keyboard: Schritt 1, Bild 1 von 3 Toshiba Satellite M45 Display Replacement, Keyboard: Schritt 1, Bild 2 von 3 Toshiba Satellite M45 Display Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Carefully use the blue iFixit Opening Tool to pry the panel above the keyboard from the left and right side.
    • Push back the screen until it is flat with the laptop.
    • Gently remove the clips that connect the panel to the screen.
  2. Toshiba Satellite M45 Display Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite M45 Display Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite M45 Display Replacement: Schritt 2, Bild 3 von 3
    • Use the Phillips #1 screwdriver to remove the two screws.
    • Gently pry the keyboard from the laptop using the blue iFixit opening tool.
    • Slowly lift the keyboard away from the laptop.
    • Remove the ribbon that connects to the laptop.
    • Ensure you remove the keyboard slowly to avoid damaging the ribbon cable.
  3. Toshiba Satellite M45 Display Replacement, Display: Schritt 3, Bild 1 von 1
    • Remove the 2-3 pieces of black electrical tape covering the black-and-white antenna cable.
    • Close the display, flip the laptop over, and disconnect the black-and-white antenna cables from the Wi-Fi card.
    • Flip the laptop back over and open the display.
  4. Toshiba Satellite M45 Display Replacement: Schritt 4, Bild 1 von 3 Toshiba Satellite M45 Display Replacement: Schritt 4, Bild 2 von 3 Toshiba Satellite M45 Display Replacement: Schritt 4, Bild 3 von 3
    • Remove the two Phillips #1 screws securing the display hinges.
    • It is recommended to keep the screws in a small cup so that you don't lose them.
    • Remove the four Phillips #1 screws on the back of the laptop.
  5. Toshiba Satellite M45 Display Replacement: Schritt 5, Bild 1 von 1
    • Gently pull up on the display's video connector to remove it.
    • Remove the black-and-white antenna cable from the groove.
    • Your display can now be removed.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Aryn Pauly
1 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 10-42, Garner Spring 2010 Mitglied von Cal Poly, Team 10-42, Garner Spring 2010
CPSU-GARNER-S10S10G42
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 13
Insgesamt: 8,121
