Einleitung
Learn how to replace your laptop's RAM.
Was du brauchst
Use a #1 Phillips head screwdriver to remove the screw on the middle right of the RAM's cover panel.
Then, use a the blue iFixit Opening Tool to pry the cover panel off.
Push on to the RAM tabs to disconnect the RAM form the device.
The RAM will pop off from the socket. Gently pull the RAM out of the socket.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
