Zum Hauptinhalt wechseln
Toshiba Satellite M55-S135 Hard Drive Replacement
Was du brauchst
  1. Toshiba Satellite M55-S135 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Use the Phillips 00 screwdriver to remove the 3.62mm screw.
  2. Toshiba Satellite M55-S135 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Remove the plastic cover from the laptop.
  3. Toshiba Satellite M55-S135 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Pull the black plastic tab horizontally away from the hard drive to disconnect and remove the hard drive from the laptop.
  4. Toshiba Satellite M55-S135 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Use the Phillips 00 screwdriver to remove the four 6.50mm screws on the sides of hard drive.
  5. Toshiba Satellite M55-S135 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite M55-S135 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Use the Phillips 00 screwdriver to remove the other four 6.50mm screws on hard drive.
    • Remove the washer strips (the metal strips that the screws held down) from the hard drive.
  6. Toshiba Satellite M55-S135 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Pull the black tab away from the hard drive to separate the hard drive and the casing.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Matthew Trinh
63 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 7-11, Maness Winter 2013 Mitglied von Cal Poly, Team 7-11, Maness Winter 2013
CPSU-MANESS-W13S7G11
4 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
I have a regular SATA 2.5 hard drive and it won't fit my M55-S1001. Is there something else I need??
Matthew Halbert - Antwort
According to http://www.rakuten.com/prod/120gb-hard-d..., your hard drive is the right size. If it doesn't fit, check to see if the pins connect correctly and if your laptop accepts a SATA drive and not a PATA drive; this image can help http://www.laptopking.com/sata_identify.....
Next, check if you're inserting it correctly. I haven't experienced replacing the hard drive with the M55-S1001, but I assume it's the same method as the M55-S135 (though it could be different).
I'm unsure if there's anything else you would need besides the correct type of screwdriver to unlock the casing but I doubt it.
Matthew Trinh - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 3,952
