Zum Hauptinhalt wechseln
Toshiba Satellite M55-S135 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite M55-S135 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Start with the laptop open and the keyboard facing you.
    • Tilt the screen away from you to reduce the risk of damaging it as you remove the keyboard.
  2. Toshiba Satellite M55-S135 Keyboard Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite M55-S135 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Locate the vertical seam between the speakers and the top row of keys on the keyboard.
    • Insert the tip of a nylon spudger into the seam and slowly pry up the panel.
    • Be sure to gently pry the panel to avoid damaging it or the laptop.
  3. Toshiba Satellite M55-S135 Keyboard Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite M55-S135 Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Remove both 6.72mm screws from the upper left and right of the keyboard using the Phillips #00 screwdriver.
  4. Toshiba Satellite M55-S135 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Use the nylon spudger to pry up the keyboard. Start with one side and then the other.
    • Be sure to pry gently with the screwdriver to avoid damaging the keyboard and keys.
  5. Toshiba Satellite M55-S135 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Gently lift the keyboard to reveal the keyboard cable located near the mouse pad.
    • Disconnect the keyboard cable.
    • Be sure to disconnect the cable before removing the keyboard to avoid damaging it.
Abschluss
klismann Evora
109 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 5-7, Cichon Spring 2014 Mitglied von UMass Dartmouth, Team 5-7, Cichon Spring 2014
UMASSD-CICHON-S14S5G7
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 706
