Zum Hauptinhalt wechseln
Toshiba Satellite M55-S135 Optical Drive Replacement
Was du brauchst
  1. Toshiba Satellite M55-S135 Optical Drive Replacement, RAM: Schritt 1, Bild 1 von 1
    • Orient the laptop so that it is closed, faced down and has the battery facing away from you.
    • Use the Phillips 00 screwdriver to remove the 7.50mm screw from the panel.
  2. Toshiba Satellite M55-S135 Optical Drive Replacement: Schritt 2, Bild 1 von 1
    • Carefully remove the cover to reveal the RAM compartment.
  3. Toshiba Satellite M55-S135 Optical Drive Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite M55-S135 Optical Drive Replacement: Schritt 3, Bild 2 von 2
    • Rotate the laptop 90 degrees clockwise.
    • Pull back the two silver clips that hold the RAM in place.
    • Gently pull the RAM out of the slot and lift up to remove the RAM from the laptop.
  4. Toshiba Satellite M55-S135 Optical Drive Replacement, Optical Drive: Schritt 4, Bild 1 von 1
    • Use the Phillips #00 screwdriver to remove the 6.50mm screw holding the gray metal bracket in place.
  5. Toshiba Satellite M55-S135 Optical Drive Replacement: Schritt 5, Bild 1 von 1
    • Turn the laptop 180 degrees then tilt the near side up.
    • Push the back side of the optical drive out of the laptop using the plastic opening tool.
  6. Toshiba Satellite M55-S135 Optical Drive Replacement: Schritt 6, Bild 1 von 1
    • Pull the optical drive out of the laptop using your fingers.
  7. Toshiba Satellite M55-S135 Optical Drive Replacement: Schritt 7, Bild 1 von 1
    • Using the Phillips 00 screwdriver, unscrew the two 2.50mm screws that connect the metal bracket to the optical drive.
    • Remove the bracket from optical drive.
Abschluss
Yuheng Huang
13 Reputation
1 Anleitung geschrieben
Cal Poly, Team 7-11, Maness Winter 2013 Mitglied von Cal Poly, Team 7-11, Maness Winter 2013
CPSU-MANESS-W13S7G11
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 637
