Zum Hauptinhalt wechseln
Toshiba Satellite P105-S6147 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite P105-S6147 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Use the iFixit opening tool to remove the cover at the top of the keyboard.
    • Insert the tool in the small space above the keyboard and gently pry until the cover pops out of its retaining clips.
    • Repeat the prying across the top of the keyboard until the whole cover is loose.
  2. Toshiba Satellite P105-S6147 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Gently lift the cover off the top of the keyboard.
  3. Toshiba Satellite P105-S6147 Keyboard Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite P105-S6147 Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Use the Phillips #0 screwdriver to remove six 6 mm screws labeled “F4” at the top of the keyboard.
  4. Toshiba Satellite P105-S6147 Keyboard Replacement: Schritt 4, Bild 1 von 3 Toshiba Satellite P105-S6147 Keyboard Replacement: Schritt 4, Bild 2 von 3 Toshiba Satellite P105-S6147 Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Use the iFixit opening tool to pry the keyboard out of its retaining clips.
    • Insert the tool into the groove surrounding the laptop and pry until the keyboard “pops” out of the laptop body.
    • Once the keyboard is free from the laptop body, gently flip the keyboard over, as seen in the third picture.
  5. Toshiba Satellite P105-S6147 Keyboard Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite P105-S6147 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Lay the keyboard down on the bottom of the laptop, as seen in image one.
    • Locate the ribbon cable connecting the bottom of the keyboard to the laptop. There will be a small black and white clip securing the ribbon cable to the laptop.
    • Use the iFixit opening tool to gently open the clip, freeing the ribbon cable from the laptop body.
    • Gently remove the keyboard from the laptop body.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 238
