Zum Hauptinhalt wechseln
Toshiba Satellite P105-S6147 RAM Replacement
  1. Toshiba Satellite P105-S6147 RAM Replacement, RAM: Schritt 1, Bild 1 von 1
    • Begin with the laptop laying down on a flat surface, with the bottom facing up.
  2. Toshiba Satellite P105-S6147 RAM Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite P105-S6147 RAM Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite P105-S6147 RAM Replacement: Schritt 2, Bild 3 von 3
    • Remove the battery from the device.
    • The battery is located in the bottom, left hand corner of the device.
    • Slide the lock switch to the unlocked position.
    • Slide the release lever towards the unlock switch. The battery should now rotate out of its dock in the laptop.
  3. Toshiba Satellite P105-S6147 RAM Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite P105-S6147 RAM Replacement: Schritt 3, Bild 2 von 2
    • Open the casing directly above the battery.
    • Use a Phillips #0 screwdriver to remove two 4 mm screws located at the top of the casing.
    • Once the cover is removed the RAM sticks will be visible.
  4. Toshiba Satellite P105-S6147 RAM Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite P105-S6147 RAM Replacement: Schritt 4, Bild 2 von 2
    • Use a nylon spudger to disconnect the tabs from the RAM. The tabs are located on either side of the RAM.
    • Apply light, outward force to the tabs.
  5. Toshiba Satellite P105-S6147 RAM Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite P105-S6147 RAM Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite P105-S6147 RAM Replacement: Schritt 5, Bild 3 von 3
    • Use the iFixit opening tool to apply light pressure to the bottom of the upper RAM stick.
    • The RAM stick should come loose and be removable by hand.
    • Repeat the previous steps to remove the lower RAM stick.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 14
Insgesamt: 187
