Zum Hauptinhalt wechseln
Toshiba Satellite P205-S8811 Hard Drive Replacement
Was du brauchst
  1. Toshiba Satellite P205-S8811 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite P205-S8811 Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the laptop over so the bottom is facing upward and the battery is on top.
    • Slide the tab below the battery to the left.
  2. Toshiba Satellite P205-S8811 Hard Drive Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite P205-S8811 Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Slide and hold the tab on the right side of the battery to the right.
    • While holding the right tab, slide the battery upward and out its socket.
  3. Toshiba Satellite P205-S8811 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 1
    • Use a #1 Phillips screwdriver to take out the 8mm Phillips #1 screw holding the hard drive panel on.
  4. Toshiba Satellite P205-S8811 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Place one finger under the tab of the hard drive panel and lift up with medium force.
  5. Toshiba Satellite P205-S8811 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite P205-S8811 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Hold the black tab attached to the hard drive and pull with medium force to the side that the tab is on. This will pull the hard drive out of it's socket.
  6. Toshiba Satellite P205-S8811 Hard Drive Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite P205-S8811 Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Use a #1 Phillips screwdriver to unscrew the four 4mm Phillips #1 screws (2 on each side) holding the brackets to the hard drive.
    • With the screws undone, the brackets should come right off. Next, pull on the black tab again to pull the cover off of the hard drive.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Andrew Meyer
245 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 2-8, Amido Winter 2014 Mitglied von Cal Poly, Team 2-8, Amido Winter 2014
CPSU-AMIDO-W14S2G8
4 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
There is a missing step between 4 and 5.
- Remove the screw(s) that hold the HDD assembly in its compartment.
...only then can you move on to step 5.
Robert Cartier - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 18
Insgesamt: 1,085
