Zum Hauptinhalt wechseln
Toshiba Satellite P205D-S8804 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite P205D-S8804 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Place the laptop with the screen facing you and grab the opening tool.
    • Insert it into the top corner of the keyboard and slide it to the right along the length of the keyboard.
    • You will feel the popping sensation as it slides along.
  2. Toshiba Satellite P205D-S8804 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Lit up the left side of the small plastic bar at the top of the keyboard.
    • Be careful when removing it, because you will need to apply a bit of force .
  3. Toshiba Satellite P205D-S8804 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Use a PH0 screwdriver to unscrew the 4 screws at the top of the keyboard.
  4. Toshiba Satellite P205D-S8804 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Lift up the keyboard and pull it toward the screen.
    • The keyboard will still be connected to the motherboard by a ribbon cable.
  5. Toshiba Satellite P205D-S8804 Keyboard Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite P205D-S8804 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • To remove the ribbon cable, push upward on the small tabs located on either side of the ribbon.
  6. Toshiba Satellite P205D-S8804 Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Once the ribbon is released the keyboard can be removed .
Abschluss
Caroline Camp
1 Reputation
3 Anleitungen geschrieben
Baylor, Team 3-2, Whitney Spring 2017 Mitglied von Baylor, Team 3-2, Whitney Spring 2017
BU-WHITNEY-S17S3G2
4 Mitglieder
4 Anleitungen geschrieben
Ein Kommentar
rename tool with a standard link for easier accessibility
Andy Feng - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 205
