Zum Hauptinhalt wechseln
Toshiba Satellite P50W-C Battery Replacement
Was du brauchst
  1. Toshiba Satellite P50W-C Battery Replacement, Back Cover: Schritt 1, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Turn the laptop off, unplug the AC adapter, and any other auxiliary components.
    • Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
  2. Toshiba Satellite P50W-C Battery Replacement: Schritt 2, Bild 1 von 1
    • Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
  3. Toshiba Satellite P50W-C Battery Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite P50W-C Battery Replacement: Schritt 3, Bild 2 von 2
    • Use the spudger to pry under the back cover until it pops off.
  4. Toshiba Satellite P50W-C Battery Replacement, Battery: Schritt 4, Bild 1 von 1
    • Unscrew the four 5 mm JIS #1 head screws holding the battery to the device and gently remove the battery.
  5. Toshiba Satellite P50W-C Battery Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite P50W-C Battery Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the battery from the motherboard by gently pulling out the black connector.
Abschluss
USF Tampa, Team S3-G2, Cannon Fall 2017 Mitglied von USF Tampa, Team S3-G2, Cannon Fall 2017
USFT-CANNON-F17S3G2
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 15
Insgesamt: 949
