Zum Hauptinhalt wechseln
Toshiba Satellite P50W-C Mother Board Replacement
Was du brauchst
  1. Toshiba Satellite P50W-C Mother Board Replacement, Back Cover: Schritt 1, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Turn the laptop off, unplug the AC adapter, and any other auxiliary components.
    • Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
  2. Toshiba Satellite P50W-C Mother Board Replacement: Schritt 2, Bild 1 von 1
    • Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
  3. Toshiba Satellite P50W-C Mother Board Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite P50W-C Mother Board Replacement: Schritt 3, Bild 2 von 2
    • Use the spudger to pry under the back cover until it pops off.
  4. Toshiba Satellite P50W-C Mother Board Replacement, Mother Board: Schritt 4, Bild 1 von 3 Toshiba Satellite P50W-C Mother Board Replacement, Mother Board: Schritt 4, Bild 2 von 3 Toshiba Satellite P50W-C Mother Board Replacement, Mother Board: Schritt 4, Bild 3 von 3
    • Remove all power connections to the motherboard. Including the black and white power connections to the wifi module.
  5. Toshiba Satellite P50W-C Mother Board Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite P50W-C Mother Board Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite P50W-C Mother Board Replacement: Schritt 5, Bild 3 von 3
    • Unscrew the two 7 mm JIS head screws in the fan .
    • Then unscrew the four 2 mm JIS head screws connecting the heat sink to the mother board.
    • Then take out the heat sink and fan.
  6. Toshiba Satellite P50W-C Mother Board Replacement: Schritt 6, Bild 1 von 1
    • Remove both 3mm JIS head screws connecting the motherboard to the device.
  7. Toshiba Satellite P50W-C Mother Board Replacement: Schritt 7, Bild 1 von 1
    • Remove 5mm silver Phillips head screw connecting black cover to the motherboard
  8. Toshiba Satellite P50W-C Mother Board Replacement: Schritt 8, Bild 1 von 2 Toshiba Satellite P50W-C Mother Board Replacement: Schritt 8, Bild 2 von 2
    • Remove all three 5 mm silver JIS head screws connecting the silver cover to the motherboard.
  9. Toshiba Satellite P50W-C Mother Board Replacement: Schritt 9, Bild 1 von 1
    • You can now gently remove the motherboard from the device.
Abschluss
Brittany Edwards
104 Reputation
1 Anleitung geschrieben
USF Tampa, Team S3-G2, Cannon Fall 2017 Mitglied von USF Tampa, Team S3-G2, Cannon Fall 2017
USFT-CANNON-F17S3G2
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 473
