Zum Hauptinhalt wechseln
Toshiba Satellite P55W-C5316 RAM Replacement
Was du brauchst
  1. Toshiba Satellite P55W-C5316 RAM Replacement, Back Panel: Schritt 1, Bild 1 von 2 Toshiba Satellite P55W-C5316 RAM Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • To prevent injury, ensure the laptop is powered off before starting your work.
    • Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
  2. Toshiba Satellite P55W-C5316 RAM Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite P55W-C5316 RAM Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite P55W-C5316 RAM Replacement: Schritt 2, Bild 3 von 3
    • Be careful to not crack the panel where the USB and power cord ports are.
    • Insert the opening tool in between the back panel and the laptop to pry it open.
    • The back panel is magnetically attached at the front of the laptop so you may have to move the opening tool along the length of the panel.
    • Lift the panel from the front off of the laptop.
  3. Toshiba Satellite P55W-C5316 RAM Replacement, Battery: Schritt 3, Bild 1 von 3 Toshiba Satellite P55W-C5316 RAM Replacement, Battery: Schritt 3, Bild 2 von 3 Toshiba Satellite P55W-C5316 RAM Replacement, Battery: Schritt 3, Bild 3 von 3
    • The battery is located in the bottom right corner of the laptop.
    • Remove the four .5mm Phillips head screws on the battery using the PH1 screwdriver.
  4. Toshiba Satellite P55W-C5316 RAM Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite P55W-C5316 RAM Replacement: Schritt 4, Bild 2 von 2
    • Do not tug on the cord or battery. Instead, pull evenly on the connector.
    • Lift the battery and gently pull out the bundled cable connector.
  5. Toshiba Satellite P55W-C5316 RAM Replacement, RAM: Schritt 5, Bild 1 von 3 Toshiba Satellite P55W-C5316 RAM Replacement, RAM: Schritt 5, Bild 2 von 3 Toshiba Satellite P55W-C5316 RAM Replacement, RAM: Schritt 5, Bild 3 von 3
    • Lift up the flap to expose the RAM chip.
    • Un-clip the RAM by pulling the metal clips away from the chip on both sides.
    • Lift the RAM up from the laptop and pull it away from the connector.
Abschluss
Alec Bonnell
497 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S3-G2, Bailey Fall 2017 Mitglied von UMass Dartmouth, Team S3-G2, Bailey Fall 2017
UMASSD-BAILEY-F17S3G2
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 14
Insgesamt: 619
