Einleitung
Use this guide to remove the Toshiba Satellite P55t-A5116 battery.
Was du brauchst
Gently pry off the bottom case with the plastic opening tools.
Find the seam between the back case and the rest of the laptop casing.
Use the #PH0 screw head, remove 4 (5.7mm) screws.
Unplug the battery's 10 pin connector and gently lift the battery out of the laptop.
12 weitere Nutzer:innen haben diese Anleitung absolviert.
9 Kommentare
The screws for the battery are in very tight and I'm having trouble unscrewing them
I'm having difficulty unplugging the 10 pin connector. Afraid if I pull too hard it will pull the wires out. Any suggestions?
Just wiggle it back-and-forth a bit and it should come out. I just change my own battery.
