Einleitung
Use this guide to remove the Toshiba Satellite P55t-A5116 Power Jack.
Was du brauchst
Gently pry off the bottom case with the plastic opening tools.
Find the seam between the back case and the rest of the laptop casing.
Use the #PH0 screw head, remove 4 (5.7mm) screws.
Unplug the battery's 10 pin connector and gently lift the battery out of the laptop.
Using the #PH0 screw head, remove 2 (5.7 mm) screws.
Remove metal plate.
Using the #PH0 screw head remove 1 (5.7mm) screw and 1 (4.15mm) screw.
Gently pull up the power jack. Follow the cord until you reach the connector.
Unplug the 4 pin connector and remove from laptop
2 weitere Nutzer:innen haben diese Anleitung absolviert.
