Zum Hauptinhalt wechseln
Toshiba Satellite P75-A7100 Fan Replacement
Was du brauchst
  1. Toshiba Satellite P75-A7100 Fan Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the tabs apart from each other.
  2. Toshiba Satellite P75-A7100 Fan Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite P75-A7100 Fan Replacement: Schritt 2, Bild 2 von 2
    • Lift the battery upwards and remove it from the device.
  3. Toshiba Satellite P75-A7100 Fan Replacement, Wi-Fi Adapter: Schritt 3, Bild 1 von 2 Toshiba Satellite P75-A7100 Fan Replacement, Wi-Fi Adapter: Schritt 3, Bild 2 von 2
    • Using a Phillips #1 screwdriver, remove the screw from the back cover.
    • Remove the back cover from the device.
  4. Toshiba Satellite P75-A7100 Fan Replacement: Schritt 4, Bild 1 von 3 Toshiba Satellite P75-A7100 Fan Replacement: Schritt 4, Bild 2 von 3 Toshiba Satellite P75-A7100 Fan Replacement: Schritt 4, Bild 3 von 3
    • Remove the optical drive from the device.
  5. Toshiba Satellite P75-A7100 Fan Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite P75-A7100 Fan Replacement: Schritt 5, Bild 2 von 2
    • Using a Phillips #1 screwdriver, unscrew the remaining screws that are visible on the laptop.
    • Remove the back cover from your device.
  6. Toshiba Satellite P75-A7100 Fan Replacement: Schritt 6, Bild 1 von 3 Toshiba Satellite P75-A7100 Fan Replacement: Schritt 6, Bild 2 von 3 Toshiba Satellite P75-A7100 Fan Replacement: Schritt 6, Bild 3 von 3
    • Using a Phillips #1 screwdriver, remove the screw connecting the Wi-Fi adapter to the motherboard.
    • Remove the Wi-Fi adapter from the device.
  7. Toshiba Satellite P75-A7100 Fan Replacement, Fan: Schritt 7, Bild 1 von 2 Toshiba Satellite P75-A7100 Fan Replacement, Fan: Schritt 7, Bild 2 von 2
    • Using a Phillips #1 screwdriver, unscrew the 6 remaining screws attached to the fan.
    • Unplug the connector connecting the fan to the motherboard.
    • Remove the fan from the device.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
How do you remove and replace the fan from from/to the heatsink? Mine is secured with a metallic tape that is not sticky once removed.
Bruce - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 21
Insgesamt: 2,280
