Zum Hauptinhalt wechseln
Toshiba Satellite P755 S5390 Touchpad Repair
Was du brauchst
  1. Toshiba Satellite P755 S5390 Touchpad Repair, Toshiba Satellite P755 S5390 Touchpad Repair: Schritt 1, Bild 1 von 3 Toshiba Satellite P755 S5390 Touchpad Repair, Toshiba Satellite P755 S5390 Touchpad Repair: Schritt 1, Bild 2 von 3 Toshiba Satellite P755 S5390 Touchpad Repair, Toshiba Satellite P755 S5390 Touchpad Repair: Schritt 1, Bild 3 von 3
    • Make sure that your laptop is powered off before starting.
    • Close the cover and turn the laptop over so that the spine is facing away from you.
  2. Toshiba Satellite P755 S5390 Touchpad Repair: Schritt 2, Bild 1 von 2 Toshiba Satellite P755 S5390 Touchpad Repair: Schritt 2, Bild 2 von 2
    • Slide and hold the locks on both sides of the battery to the unlocked position.
    • Slide and lift the battery out of its compartment.
  3. Toshiba Satellite P755 S5390 Touchpad Repair: Schritt 3, Bild 1 von 1
    • Use the Philips #1 screwdriver to remove the 15 screws from the base of the laptop.
    • Keep track of these screws, you will need them in reassembly.
  4. Toshiba Satellite P755 S5390 Touchpad Repair: Schritt 4, Bild 1 von 1
    • Turn the laptop back over.
    • Open the cover.
  5. Toshiba Satellite P755 S5390 Touchpad Repair: Schritt 5, Bild 1 von 3 Toshiba Satellite P755 S5390 Touchpad Repair: Schritt 5, Bild 2 von 3 Toshiba Satellite P755 S5390 Touchpad Repair: Schritt 5, Bild 3 von 3
    • Using either the iFixit opening tool or your hands, gently remove the keyboard from the base panel.
    • Do not touch the motherboard.
  6. Toshiba Satellite P755 S5390 Touchpad Repair: Schritt 6, Bild 1 von 2 Toshiba Satellite P755 S5390 Touchpad Repair: Schritt 6, Bild 2 von 2
    • Check if the touch pad cable is plugged into the ZIF connector on the motherboard.
  7. Toshiba Satellite P755 S5390 Touchpad Repair: Schritt 7, Bild 1 von 3 Toshiba Satellite P755 S5390 Touchpad Repair: Schritt 7, Bild 2 von 3 Toshiba Satellite P755 S5390 Touchpad Repair: Schritt 7, Bild 3 von 3
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Michigan Tech, Team 1-20, Lauer Spring 2016 Mitglied von Michigan Tech, Team 1-20, Lauer Spring 2016
MTU-LAUER-S16S1G20
1 Mitglied
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 30
Insgesamt: 6,663
