Zum Hauptinhalt wechseln
Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement
Was du brauchst
  1. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement, Battery: Schritt 1, Bild 1 von 1
    • First flip the device over so that the back side is facing upwards
  2. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: Schritt 2, Bild 1 von 1
    • Push the two sliders toward the edge of the laptop.
    • Remove the battery.
  3. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement, Display Assembly: Schritt 3, Bild 1 von 1
    • Open the lid.
  4. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: Schritt 4, Bild 1 von 3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: Schritt 4, Bild 2 von 3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: Schritt 4, Bild 3 von 3
    • Remove the four screw covers in each of the four corners of the screen.
  5. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: Schritt 5, Bild 3 von 3
    • Remove the 4 screws in each of the 4 corners.
  6. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: Schritt 6, Bild 1 von 3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: Schritt 6, Bild 2 von 3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: Schritt 6, Bild 3 von 3
    • Take your prying tool and proceed to pry the screen cover off and set to the side.
  7. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the wire from the camera and the backside of the display assembly.
  8. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: Schritt 8, Bild 1 von 3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: Schritt 8, Bild 2 von 3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: Schritt 8, Bild 3 von 3
    • Remove the 6 screws holding the display assembly and holding brackets together.
Abschluss
Jacob Volcke
665 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 69
