Zum Hauptinhalt wechseln
Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement
Was du brauchst
  1. Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement, Battery: Schritt 1, Bild 2 von 2
    • Push the locking tabs away from each other.
  2. Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement: Schritt 2, Bild 2 von 2
    • Pull up on the battery to remove.
  3. Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement, RAM: Schritt 3, Bild 1 von 2 Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement, RAM: Schritt 3, Bild 2 von 2
    • Remove the 3mm Phillips #0 screw from the cover.
  4. Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement: Schritt 4, Bild 1 von 3 Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement: Schritt 4, Bild 2 von 3 Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement: Schritt 4, Bild 3 von 3
    • Use a plastic opening tool to lift up the cover and remove by hand.
  5. Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement: Schritt 5, Bild 3 von 3
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    • When released, the RAM module will pop up at a slight angle.
Lift the RAM module to an angle of about 30 degrees and slide it out.
  6. Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement, Keyboard: Schritt 6, Bild 1 von 2 Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement, Keyboard: Schritt 6, Bild 2 von 2
    • Use a plastic opening tool to pry up the keyboard cover.
  7. Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement: Schritt 7, Bild 1 von 2 Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement: Schritt 7, Bild 2 von 2
    • Use a plastic opening tool to pry up the keyboard.
  8. Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement: Schritt 8, Bild 1 von 3 Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement: Schritt 8, Bild 2 von 3 Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement: Schritt 8, Bild 3 von 3
    • Lay the keyboard upright against the screen.
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Remove the ribbon cable from the socket.
  9. Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement, CPU Cooling Fan: Schritt 9, Bild 1 von 2 Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement, CPU Cooling Fan: Schritt 9, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use a set of small tweezers to pull the 10 rubber caps out of the back panel.
    • Each rubber cap will only fit in the holes they came out of so keep track of which caps go where. If you lose track, there are identification letters and numbers on each cap.
  10. Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement: Schritt 10, Bild 1 von 3 Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement: Schritt 10, Bild 2 von 3 Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement: Schritt 10, Bild 3 von 3
    • Remove these thirteen Phillips #0 screws from the bottom case:
    • Ten 3mm screws.
    • Three 2mm screws.
  11. Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement: Schritt 11, Bild 1 von 2 Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement: Schritt 11, Bild 2 von 2
    • Remove the four 3mm Phillips #0 screws found underneath the keyboard.
  12. Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement: Schritt 12, Bild 1 von 2 Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement: Schritt 12, Bild 2 von 2
    • Separate the top and bottom panels from each other.
    • Try starting from the corner.
  13. Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement: Schritt 13, Bild 1 von 3 Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement: Schritt 13, Bild 2 von 3 Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement: Schritt 13, Bild 3 von 3
    • Remove the three 3mm Phillips #0 screws from the fan.
  14. Toshiba Satellite P855-S5102 CPU Cooling Fan Replacement: Schritt 14, Bild 1 von 1
    • Disconnect the fan's power from the motherboard.
    • Remove the fan from the laptop.
Abschluss
USF Tampa, Team S20-G3, Passmore Spring 2018 Mitglied von USF Tampa, Team S20-G3, Passmore Spring 2018
USFT-PASSMORE-S18S20G3
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 796
