Zum Hauptinhalt wechseln
Toshiba Satellite P855-S5102 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite P855-S5102 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 2 Toshiba Satellite P855-S5102 Keyboard Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Use a plastic opening tool to pry up the keyboard cover.
  2. Toshiba Satellite P855-S5102 Keyboard Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite P855-S5102 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool to pry up the keyboard.
  3. Toshiba Satellite P855-S5102 Keyboard Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite P855-S5102 Keyboard Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite P855-S5102 Keyboard Replacement: Schritt 3, Bild 3 von 3
    • Lay the keyboard upright against the screen.
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Remove the ribbon cable from the socket.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Benson Smith
351 Reputation
3 Anleitungen geschrieben
USF Tampa, Team S20-G3, Passmore Spring 2018 Mitglied von USF Tampa, Team S20-G3, Passmore Spring 2018
USFT-PASSMORE-S18S20G3
4 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
Proceeding this way you will get to break all seals that join that “cover“ to the rest of the keyboard assembly, rendering it unusable if you were not replacing it (in the “step 2“ photos you get to see all the broken pins where the joined parts used to be). In fact, you have to proceed from the other side and remove the cover from under the computer, there you’ll find some small tabs towards the touchpad end of things, you gently pry each tab while loosening that side of the keyboard and it rises up. Be careful not to break the flex circuit that joins it to the mainboard in the process.
Kenneth - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 413
