Zum Hauptinhalt wechseln
Toshiba Satellite P855-S5312 Disk Drive Replacement
Was du brauchst
  1. Toshiba Satellite P855-S5312 Disk Drive Replacement, Battery: Schritt 1, Bild 1 von 3 Toshiba Satellite P855-S5312 Disk Drive Replacement, Battery: Schritt 1, Bild 2 von 3 Toshiba Satellite P855-S5312 Disk Drive Replacement, Battery: Schritt 1, Bild 3 von 3
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Disk Drive Replacement, Disk Drive: Schritt 2, Bild 1 von 2 Toshiba Satellite P855-S5312 Disk Drive Replacement, Disk Drive: Schritt 2, Bild 2 von 2
    • Once laptop is turned over with the spine facing you, locate the large L shape panel.
    • Using a Philips #0 screwdriver unscrew the 1.5mm screw towards the bottom of the laptop.
  3. Toshiba Satellite P855-S5312 Disk Drive Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite P855-S5312 Disk Drive Replacement: Schritt 3, Bild 2 von 2
    • Open the motherboard access cover.
  4. Toshiba Satellite P855-S5312 Disk Drive Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite P855-S5312 Disk Drive Replacement: Schritt 4, Bild 2 von 2
    • Using a Philips #0 screwdriver, unscrew the 1.5mm screw located near the left edge of the opening near the mother board.
  5. Toshiba Satellite P855-S5312 Disk Drive Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite P855-S5312 Disk Drive Replacement: Schritt 5, Bild 2 von 2
    • Gently pull the entire disk drive assembly out.
  6. Toshiba Satellite P855-S5312 Disk Drive Replacement: Schritt 6, Bild 1 von 3 Toshiba Satellite P855-S5312 Disk Drive Replacement: Schritt 6, Bild 2 von 3 Toshiba Satellite P855-S5312 Disk Drive Replacement: Schritt 6, Bild 3 von 3
    • Flip your device over and rotate the side of the optical drive over to you.
    • Unclip the clips on the side of the automatic release.
    • Use a paper clip or small needle tool to insert in the manual release located on the right of the automatic release button.
    • Once released slide the aluminum case out.
Abschluss
Bishop Clark
225 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S10-G2, Thompson Fall 2017 Mitglied von USF Tampa, Team S10-G2, Thompson Fall 2017
USFT-THOMPSON-F17S10G2
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 466
