Zum Hauptinhalt wechseln
Toshiba Satellite P855-S5312 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 3 Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 3 Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: Schritt 2, Bild 1 von 3 Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: Schritt 2, Bild 2 von 3 Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: Schritt 2, Bild 3 von 3
    • Using plastic spudger to pry up the edges of the keyboard and lift it towards the screen.
    • Unplug the ZIF connector ribbon using the plastic spudger by gently prying the edges of the plug.
    • Remove the keyboard from the device.
Abschluss
To reassemble your device, plug the ribbon into circuit board and snap the replacement keyboard in place.
Dalton
215 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S10-G2, Thompson Fall 2017 Mitglied von USF Tampa, Team S10-G2, Thompson Fall 2017
USFT-THOMPSON-F17S10G2
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 13
Insgesamt: 1,212
