Einleitung
This guide will show you how to replace the disk drive. You may need to replace the disk drive if you can't read any CDs or DVDs.
Was du brauchst
Turn off the laptop.
Turn the laptop over and locate the battery.
Push the small switch near the corner of the laptop to the unlocked position.
Push the bigger switch in the direction of the icon and pull the battery away from the laptop.
Push the end of a paperclip into the small hole on the disk drive to open it if there is a disk that is stuck in the drive.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
