Zum Hauptinhalt wechseln
Toshiba Satellite R15-S829 Hard Drive Replacement
Was du brauchst
  1. Toshiba Satellite R15-S829 Hard Drive Replacement, Battery Replacement: Schritt 1, Bild 1 von 1
    • Unplug the charging cable from the laptop.
    • Turn off the laptop.
    • Turn the laptop over and locate the battery.
  2. Toshiba Satellite R15-S829 Hard Drive Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite R15-S829 Hard Drive Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite R15-S829 Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Push the small switch near the corner of the laptop to the unlocked position.
    • Push the bigger switch in the direction of the icon and pull the battery away from the laptop.
  3. Toshiba Satellite R15-S829 Hard Drive Replacement, Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • First, begin by locating the spot of the cover of the hard drive located on the bottom of the laptop.
  4. Toshiba Satellite R15-S829 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Remove the screw of the cover.
  5. Toshiba Satellite R15-S829 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite R15-S829 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Locate the indent where the hard drive can be removed. Remove the cover.
  6. Toshiba Satellite R15-S829 Hard Drive Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite R15-S829 Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Remove the hard drive using your hand.
  7. Toshiba Satellite R15-S829 Hard Drive Replacement: Schritt 7, Bild 1 von 3 Toshiba Satellite R15-S829 Hard Drive Replacement: Schritt 7, Bild 2 von 3 Toshiba Satellite R15-S829 Hard Drive Replacement: Schritt 7, Bild 3 von 3
    • Now remove the power ribbon from the hard drive.
  8. Toshiba Satellite R15-S829 Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Locate the screws on each side of the encasing of the hard drive.
  9. Toshiba Satellite R15-S829 Hard Drive Replacement: Schritt 9, Bild 1 von 2 Toshiba Satellite R15-S829 Hard Drive Replacement: Schritt 9, Bild 2 von 2
    • Use your Phillips screwdriver to remove the screws and be careful not to lose the screws.
  10. Toshiba Satellite R15-S829 Hard Drive Replacement: Schritt 10, Bild 1 von 1
    • Remove the encasing from the hard drive.
Abschluss
Mike Strother
299 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 5-8, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 5-8, Martin Fall 2016
UMASSD-MARTIN-F16S5G8
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 419
