Zum Hauptinhalt wechseln
Toshiba Satellite R15-S829 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite R15-S829 Keyboard Replacement, Battery Replacement: Schritt 1, Bild 1 von 1
    • Unplug the charging cable from the laptop.
    • Turn off the laptop.
    • Turn the laptop over and locate the battery.
  2. Toshiba Satellite R15-S829 Keyboard Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite R15-S829 Keyboard Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite R15-S829 Keyboard Replacement: Schritt 2, Bild 3 von 3
    • Push the small switch near the corner of the laptop to the unlocked position.
    • Push the bigger switch in the direction of the icon and pull the battery away from the laptop.
  3. Toshiba Satellite R15-S829 Keyboard Replacement, Keyboard Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite R15-S829 Keyboard Replacement, Keyboard Replacement: Schritt 3, Bild 2 von 2
    • First, begin by removing the plastic cover that is located at the top of the keyboard. This can be pried off or just removed by hand by grabbing the plastic piece by the indent on either side and lifting up.
    • Be careful to avoid breaking the plastic.
  4. Toshiba Satellite R15-S829 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Locate the two screws on each side.
  5. Toshiba Satellite R15-S829 Keyboard Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite R15-S829 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the two screws with a phillips head screwdriver. Be careful not to lose the screws.
  6. Toshiba Satellite R15-S829 Keyboard Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite R15-S829 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Lift the keyboard up to reveal the power plug.
  7. Toshiba Satellite R15-S829 Keyboard Replacement: Schritt 7, Bild 1 von 2 Toshiba Satellite R15-S829 Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the keyboard from the laptop by unplugging the power ribbon.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Mike Strother
299 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 5-8, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 5-8, Martin Fall 2016
UMASSD-MARTIN-F16S5G8
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 189
