Zum Hauptinhalt wechseln
Toshiba Satellite R15-S829 RAM Replacement
Was du brauchst
  1. Toshiba Satellite R15-S829 RAM Replacement, Battery Replacement: Schritt 1, Bild 1 von 1
    • Unplug the charging cable from the laptop.
    • Turn off the laptop.
    • Turn the laptop over and locate the battery.
  2. Toshiba Satellite R15-S829 RAM Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite R15-S829 RAM Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite R15-S829 RAM Replacement: Schritt 2, Bild 3 von 3
    • Push the small switch near the corner of the laptop to the unlocked position.
    • Push the bigger switch in the direction of the icon and pull the battery away from the laptop.
  3. Toshiba Satellite R15-S829 RAM Replacement, RAM Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite R15-S829 RAM Replacement, RAM Replacement: Schritt 3, Bild 2 von 2
    • Locate the cover where the RAM is located.
    • Locate the screw.
  4. Toshiba Satellite R15-S829 RAM Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite R15-S829 RAM Replacement: Schritt 4, Bild 2 von 2
    • Loosen the screw for the cover. The screw is attached to the cover, so you don't need to worry about losing it.
    • Lift the cover.
  5. Toshiba Satellite R15-S829 RAM Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite R15-S829 RAM Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite R15-S829 RAM Replacement: Schritt 5, Bild 3 von 3
    • Push the two silver tabs outward so that the RAM can move upward.
    • Pull the first RAM module out of the socket.
  6. Toshiba Satellite R15-S829 RAM Replacement: Schritt 6, Bild 1 von 3 Toshiba Satellite R15-S829 RAM Replacement: Schritt 6, Bild 2 von 3 Toshiba Satellite R15-S829 RAM Replacement: Schritt 6, Bild 3 von 3
    • The second RAM is removed in the same way as the first.
    • Push the tabs outward and pull out the RAM.
Abschluss
Justin Slater
128 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 5-8, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 5-8, Martin Fall 2016
UMASSD-MARTIN-F16S5G8
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 139
