Zum Hauptinhalt wechseln
Toshiba Satellite Radius P55W-B5220 Back Cover Replacement
Was du brauchst
  1. Toshiba Satellite Radius P55W-B5220 Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Turn off the laptop before starting.
    • Remove the two rubber feet closest to the hinge with a plastic opening tool.
  2. Toshiba Satellite Radius P55W-B5220 Back Cover Replacement: Schritt 2, Bild 1 von 1
    • Remove the twelve M2x4mm PH0 Philips head screws.
  3. Toshiba Satellite Radius P55W-B5220 Back Cover Replacement: Schritt 3, Bild 1 von 1
    • Loosen the back cover with a plastic opening tool.
    • The least damaging way to pry the cover is to start from a corner and run the spudger along the edge.
    • Do not crack or bend the cover.
  4. Toshiba Satellite Radius P55W-B5220 Back Cover Replacement: Schritt 4, Bild 1 von 1
    • Carefully lift open the cover.
    • Remove the attached purple ribbon cable underneath the cover.
    • Do not rip the ribbon cable.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Devin Boski
478 Reputation
3 Anleitungen geschrieben
Ein Kommentar
Can you show replace this model display, and please please, give de part number of the screen
Erick Ramon Garibay Valencia - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 1,283
