Zum Hauptinhalt wechseln
Toshiba Satellite Radius P55W-B5220 Motherboard Replacement
Was du brauchst
  1. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 2 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 2
    • Using the plastic opening tool, remove the two rubber feet closest to the hinge.
  2. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the 12 M2x4mm PH0 Philips screws.
  3. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Near the hinges, wedge a plastic opening tool under the back panel.
  4. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Unlatch the LED indicator from the back panel.
  5. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Using a P0 Philips head screwdriver, Remove the four M2x2.5mm P0 Philips screws from the battery.
  6. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Lift the battery.
    • Disconnect the battery.
  7. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 7, Bild 1 von 3 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 7, Bild 2 von 3 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Disconnect the ribbon cable of the touchpad from the motherboard.
  8. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 8, Bild 1 von 2 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Remove the two M2x2.5mm P0 Philips screws from the fan.
  9. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 9, Bild 1 von 3 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 9, Bild 2 von 3 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Disconnect the fan cables.
    • Carefully unhook the wires from the base of the fan.
  10. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Unscrew the four M2x4mm PH0 Philips screws from the CPU mounts on the motherboard.
  11. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 11, Bild 1 von 3 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 11, Bild 2 von 3 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 11, Bild 3 von 3
    • Carefully lift the heatsink off the CPU.
    • Avoid bending or kinking the tubing.
    • Delicately lift the fan out with the heatsink.
  12. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Remove the M2x2.5mm P0 Philips screw from the USB controller.
  13. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 13, Bild 1 von 3 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 13, Bild 2 von 3 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 13, Bild 3 von 3
    • Lift the USB controller from the motherboard.
    • Detach the USB controller from the motherboard.
  14. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 14, Bild 1 von 1
    • Disconnect the left speaker from the motherboard.
  15. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 15, Bild 1 von 2 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 15, Bild 2 von 2
    • Remove the two M2x4mm PH0 Philips screws for the speaker mounts.
  16. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 16, Bild 1 von 1
    • Unhook the speaker from under the hinge cable mounts.
  17. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 17, Bild 1 von 1
    • Unhook the right speaker cable from the motherboard.
  18. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 18, Bild 1 von 1
    • Remove the copper tape from the speaker cord.
  19. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 19, Bild 1 von 2 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 19, Bild 2 von 2
    • Unhook the speaker cables from under the catch under the hinge.
  20. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 20, Bild 1 von 1
    • Remove the eight M2x2.5mm P0 Philips screws from the motherboard.
  21. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: Schritt 21, Bild 1 von 1
    • Remove the motherboard.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Nicole Kohm
131 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 1,645
