Zum Hauptinhalt wechseln
Toshiba Satellite U405D-S2902 RAM Replacement
Was du brauchst
  1. Toshiba Satellite U405D-S2902 RAM Replacement, RAM: Schritt 1, Bild 1 von 2 Toshiba Satellite U405D-S2902 RAM Replacement, RAM: Schritt 1, Bild 2 von 2
    • Lay the device face down with the battery facing away from you. Locate the center panel. It will have two vents in it and three screws on the left side.
    • Loosen the three screws that hold the rear access panel on, using your Phillips #1 Screwdriver.
    • The screws will not actually come out from the panel but will be loose and let the panel come off.
    • Lift the left side of the panel to remove it.
  2. Toshiba Satellite U405D-S2902 RAM Replacement: Schritt 2, Bild 1 von 1
    • Locate and pull back the two mounting clips on either side of the memory chip.
    • Be sure that when replacing the board, push down gently until the clips snap back in.
  3. Toshiba Satellite U405D-S2902 RAM Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite U405D-S2902 RAM Replacement: Schritt 3, Bild 2 von 2
    • Lift RAM circuit board to about a 45 degree angle and pull gently to the right.
Abschluss
That's it for hardware, the remaining steps will depend on the software platform being run on your laptop.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 7-8, Maness Winter 2013 Mitglied von Cal Poly, Team 7-8, Maness Winter 2013
CPSU-MANESS-W13S7G8
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 617
