Zum Hauptinhalt wechseln
Toshiba Satellite U925T-S2120 Hard Drive Replacement
Was du brauchst
  1. Toshiba Satellite U925T-S2120 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 2 Toshiba Satellite U925T-S2120 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to pinch and pull out and remove the nine rubber gripper pads on the back panel of the laptop. Set aside.
  2. Toshiba Satellite U925T-S2120 Hard Drive Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite U925T-S2120 Hard Drive Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite U925T-S2120 Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Unscrew nine 5.8 mm screws using a PH1 screwdriver and turning clockwise.
    • Use the same screwdriver to remove the two 6.8 mm screws.
  3. Toshiba Satellite U925T-S2120 Hard Drive Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite U925T-S2120 Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Remove the back panel open by inserting the plastic opening tool into the seam of the laptop and pushing downwards. Repeat the motion around the perimeter of the device.
  4. Toshiba Satellite U925T-S2120 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Gently pop out the tab connected to the orange plastic strip.
  5. Toshiba Satellite U925T-S2120 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Hold back the orange plastic strip with one hand
    • Use a PH1 screwdriver to unscrew the two 3.4 mm screws by turning clockwise.
  6. Toshiba Satellite U925T-S2120 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Lift the silver flap away from the hard drive.
    • Gently pinch and lift out the hard drive with your thumb and pointer finger.
  7. Toshiba Satellite U925T-S2120 Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Completely remove the hard drive from the device.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Terry
137 Reputation
1 Anleitung geschrieben
Baylor, Team S5-G5, Williams Spring 2017 Mitglied von Baylor, Team S5-G5, Williams Spring 2017
BU-WILLIAMS-S17S5G5
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 18
Insgesamt: 1,794
