Zum Hauptinhalt wechseln
Toshiba Satellite e205 Hard Drive Replacement
Was du brauchst
  1. Toshiba Satellite e205 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite e205 Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • With the battery away from you, slide the locking clips out.
    • The left clip stays, the right clip is spring loaded.
    • Slide the battery away from you.
  2. Toshiba Satellite e205 Hard Drive Replacement, Keyboard: Schritt 2, Bild 1 von 1
    • Use a spudger to carefully pry up the keyboard screw cover.
  3. Toshiba Satellite e205 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Remove the two screws securing the keyboard to the chassis.
  4. Toshiba Satellite e205 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Carefully tilt the keyboard towards you and release the ribbon cables.
    • Use a spudger if needed to release the latch. The latch slides out.
    • The keyboard is now free and can be set aside.
  5. Toshiba Satellite e205 Hard Drive Replacement, Bottom Cover: Schritt 5, Bild 1 von 1
    • Remove the five black screws
    • Remove the one silver screw
  6. Toshiba Satellite e205 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Flip the laptop over so the bottom is facing up.
    • Using a spudger, remove the seven rubber inserts.
    • The feet only go in one location on the bottom of the laptop, so save yourself some time and track where they go.
  7. Toshiba Satellite e205 Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Remove the six silver screws.
    • Remove the one black screw.
  8. Toshiba Satellite e205 Hard Drive Replacement: Schritt 8, Bild 1 von 2 Toshiba Satellite e205 Hard Drive Replacement: Schritt 8, Bild 2 von 2
    • Stand the laptop up on end.
    • Remove the two rubber inserts from the back of the laptop. One insert is on each side of the laptop.
  9. Toshiba Satellite e205 Hard Drive Replacement: Schritt 9, Bild 1 von 2 Toshiba Satellite e205 Hard Drive Replacement: Schritt 9, Bild 2 von 2
    • Remove the two screews.
  10. Toshiba Satellite e205 Hard Drive Replacement: Schritt 10, Bild 1 von 1
    • Carefully work a spudger in the crack at the back of the laptop and separate the small rubberized section from the bottom of the laptop.
  11. Toshiba Satellite e205 Hard Drive Replacement: Schritt 11, Bild 1 von 1
    • Remove the four screws.
    • Disconnect the black wireless antenna lead.
  12. Toshiba Satellite e205 Hard Drive Replacement: Schritt 12, Bild 1 von 1
    • The bottom of the laptop is now ready to lift off.
    • Carefully work a spudger around the seam of the laptop separating the bottom from the rest of the laptop.
    • There is a data connection at the front of the laptop that needs to be disconnected.
    • Use a spuder to carefully disconnect the wire from the motherboard. Once this is free the bottom will come off.
  13. Toshiba Satellite e205 Hard Drive Replacement, Hard Drive: Schritt 13, Bild 1 von 2 Toshiba Satellite e205 Hard Drive Replacement, Hard Drive: Schritt 13, Bild 2 von 2
    • Locate the hard drive.
    • Remove the three screws.
    • Slide the hard drive out away from the motherboard connector.
    • Once the hard drive is disconnected it lifts out.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Tyler
4.920 Reputation
16 Anleitungen geschrieben
TechForce Mitglied von TechForce
Business
2 Mitglieder
25 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 4,156
