Zum Hauptinhalt wechseln
Toshiba Satellite e205 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite e205 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite e205 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • With the battery away from you, slide the locking clips out.
    • The left clip stays, the right clip is spring loaded.
    • Slide the battery away from you.
  2. Toshiba Satellite e205 Keyboard Replacement, Keyboard: Schritt 2, Bild 1 von 1
    • Use a spudger to carefully pry up the keyboard screw cover.
  3. Toshiba Satellite e205 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the two screws securing the keyboard to the chassis.
  4. Toshiba Satellite e205 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Carefully tilt the keyboard towards you and release the ribbon cables.
    • Use a spudger if needed to release the latch. The latch slides out.
    • The keyboard is now free and can be set aside.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Tyler
4.920 Reputation
16 Anleitungen geschrieben
TechForce Mitglied von TechForce
Business
2 Mitglieder
25 Anleitungen geschrieben
2 Kommentare
What is the brass colored ribbon for? Mine is broken will it effect funconality , if so how do i fix it
Kathleen T - Antwort
If I remember correctly, this keyboard is backlit. Most likely the copper cable is for the backlit power. A new keyboard would need to be purchased to fix it.
Tyler - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 16
Insgesamt: 657
