Zum Hauptinhalt wechseln
Unihertz Titan Pocket keyboard Disassembly
Was du brauchst
  1. Unihertz Titan Pocket keyboard Disassembly, Side plates disassembly: Schritt 1, Bild 1 von 3 Unihertz Titan Pocket keyboard Disassembly, Side plates disassembly: Schritt 1, Bild 2 von 3 Unihertz Titan Pocket keyboard Disassembly, Side plates disassembly: Schritt 1, Bild 3 von 3
    • Use a Torx T5 screwdriver to remove the 3 screws.
    • Remove the Sim tray.
  2. Unihertz Titan Pocket keyboard Disassembly, Back plate screws: Schritt 2, Bild 1 von 1
    • Use a Torx T5 screwdriver to remove the 4 screws.
  3. Unihertz Titan Pocket keyboard Disassembly, Back plate disassembly: Schritt 3, Bild 1 von 3 Unihertz Titan Pocket keyboard Disassembly, Back plate disassembly: Schritt 3, Bild 2 von 3 Unihertz Titan Pocket keyboard Disassembly, Back plate disassembly: Schritt 3, Bild 3 von 3
    • Insert the opening pick into the gap between the body and the back plate. Then open the gap so that the latch comes out.
    • There are three latches on the left and right, one on the top and two on the bottom.
  4. Unihertz Titan Pocket keyboard Disassembly, Bottom part disassembly: Schritt 4, Bild 1 von 3 Unihertz Titan Pocket keyboard Disassembly, Bottom part disassembly: Schritt 4, Bild 2 von 3 Unihertz Titan Pocket keyboard Disassembly, Bottom part disassembly: Schritt 4, Bild 3 von 3
    • Remove the 3 screws using a Phillips #000 screwdriver.
    • Use the opening tool to open the gap.
  5. Unihertz Titan Pocket keyboard Disassembly, Battery disassembly: Schritt 5, Bild 1 von 3 Unihertz Titan Pocket keyboard Disassembly, Battery disassembly: Schritt 5, Bild 2 von 3 Unihertz Titan Pocket keyboard Disassembly, Battery disassembly: Schritt 5, Bild 3 von 3
    • Remove the battery connector.
    • Do not remove including a black sponge. Only disconnect the silver connector.
    • Then, lift the battery.
  6. Unihertz Titan Pocket keyboard Disassembly, Upper part disassembly: Schritt 6, Bild 1 von 3 Unihertz Titan Pocket keyboard Disassembly, Upper part disassembly: Schritt 6, Bild 2 von 3 Unihertz Titan Pocket keyboard Disassembly, Upper part disassembly: Schritt 6, Bild 3 von 3
    • Remove the 2 screws using a Phillips #000 screwdriver.
    • Lift the top part with the pointed part of the Spudger.
    • You don't have to remove the metal sticker by just lifting the top part.
    • If the camera or earphone jack connector is disconnected during the lifting process, reconnect it.
  7. Unihertz Titan Pocket keyboard Disassembly, Motherboard disassembly: Schritt 7, Bild 1 von 3 Unihertz Titan Pocket keyboard Disassembly, Motherboard disassembly: Schritt 7, Bild 2 von 3 Unihertz Titan Pocket keyboard Disassembly, Motherboard disassembly: Schritt 7, Bild 3 von 3
    • Disconnect the 6 connectors.
    • Remove the 5 screws using a Phillips #000 screwdriver.
    • Use the Spudger to lift the top of the motherboard.
  8. Unihertz Titan Pocket keyboard Disassembly, Keyboard disassembly: Schritt 8, Bild 1 von 3 Unihertz Titan Pocket keyboard Disassembly, Keyboard disassembly: Schritt 8, Bild 2 von 3 Unihertz Titan Pocket keyboard Disassembly, Keyboard disassembly: Schritt 8, Bild 3 von 3
    • Insert a thin thing such as a Sim pin through the hole where the screw was removed and push the keyboard out.
  9. Unihertz Titan Pocket keyboard Disassembly, Keyboard disassembly: Schritt 9, Bild 1 von 1
    • Remove the 17 plastic rivets to separate the board and keyboard.
    • Since plastic rivets cannot be reused after they are initially removed, they must be reassembled using tools such as glue.
Abschluss
To reassemble the device, follow the instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
ko en
100%
glwps hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
glwps
253 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 31
Letzte 30 Tage: 128
Insgesamt: 746
