Einleitung
This guide will help cover a left undone outlet hole or if you are putting a new outlet cover. This guide will help prevent a hazardous zone for children, especially for children under three years old, who can easily put the cord in their mouth or get their hand stuck inside the wall. The guide will also prevent any bugs or mice to get in and out of the hole and it would be best if the hole would be covered up with a proper blank wall outlet cover and this guide is here to help you do that.
Was du brauchst
Line up the screws in the plate with the screw holes in the wall.
Tighten the screws slightly with your hands to ensure that both screws have found the proper holes.
Double check that the wall cover plate does not have a gap, and it is completely attached to the wall.
If any gap is detected, push the plate to the wall and continue to tighten the screws until the gap completely closes.
