Einleitung
The Wyze Cam Camera has a 110º wide angle lens, 8x digital zoom, and enhanced night vision. If your camera quality declines, or stops working you might need to replace it. This guide will walk you through getting your camera replaced.
Was du brauchst
Open up the camera stand to expose the bottom plate of the camera.
Remove two 4 mm silver screws using the Phillips #0 screwdriver.
Using the iFixit opening tool, carefully pry open the bottom plate to gain access to the camera's internals.
Open up the back panel using the iFixit opening tool and unclip the panel from the rest of the device.
In diesem Schritt verwendetes Werkzeug:Tweezers$3.99
Using the angled slim tweezers, disconnect the cord and pull it gently off of the motherboard.
Remove the single 6 mm screw located deep inside the device using a Phillips #000 screwdriver.
Carefully remove the motherboard from the device.
Remove the remaining two 6 mm screws from the motherboard with a Phillips #0 screwdriver.
Remove four 4 mm screws from the back of the camera using a Phillips #0 screwdriver.
