Zum Hauptinhalt wechseln
Xiaomi Yi Back Panel Replacement
Was du brauchst
  1. Xiaomi Yi Back Panel Replacement, Battery: Schritt 1, Bild 1 von 2 Xiaomi Yi Back Panel Replacement, Battery: Schritt 1, Bild 2 von 2
    • Push the battery door switch to the left.
    • Lift the battery door up.
  2. Xiaomi Yi Back Panel Replacement: Schritt 2, Bild 1 von 3 Xiaomi Yi Back Panel Replacement: Schritt 2, Bild 2 von 3 Xiaomi Yi Back Panel Replacement: Schritt 2, Bild 3 von 3
    • Lift the battery tab up.
    • Remove the battery by pulling the removal tab.
  3. Xiaomi Yi Back Panel Replacement, Front Panel: Schritt 3, Bild 1 von 2 Xiaomi Yi Back Panel Replacement, Front Panel: Schritt 3, Bild 2 von 2
    • Introduce the plastic opening tool into any of the sides of the camera.
    • Pry with the plastic opening tool at the seam between the front and the back panel.
  4. Xiaomi Yi Back Panel Replacement: Schritt 4, Bild 1 von 3 Xiaomi Yi Back Panel Replacement: Schritt 4, Bild 2 von 3 Xiaomi Yi Back Panel Replacement: Schritt 4, Bild 3 von 3
    • Slide prying tool along the seam until front panel is fully separated from the back panel.
  5. Xiaomi Yi Back Panel Replacement, Back Panel: Schritt 5, Bild 1 von 2 Xiaomi Yi Back Panel Replacement, Back Panel: Schritt 5, Bild 2 von 2
    • Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard.
  6. Xiaomi Yi Back Panel Replacement: Schritt 6, Bild 1 von 3 Xiaomi Yi Back Panel Replacement: Schritt 6, Bild 2 von 3 Xiaomi Yi Back Panel Replacement: Schritt 6, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Pull on and remove the black spacer located at the top inside of the camera body using the tweezers and set the part aside.
  7. Xiaomi Yi Back Panel Replacement: Schritt 7, Bild 1 von 2 Xiaomi Yi Back Panel Replacement: Schritt 7, Bild 2 von 2
    • Remove the motherboard from from the back case by gently pulling on the lens housing.
    • Back panel remains.
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 15-5, Blackwell Fall 2015 Mitglied von USF Tampa, Team 15-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G5
3 Mitglieder
10 Anleitungen geschrieben
2 Kommentare
Where can I buy back panel for Xiaomi Yi?
matulek - Antwort
Where can i buy the back panel replacement ?
Roland Meilleur - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 23
Insgesamt: 3,581
