Zum Hauptinhalt wechseln
Xiaomi Yi Front Panel Replacement
Was du brauchst
  1. Xiaomi Yi Front Panel Replacement, Battery: Schritt 1, Bild 1 von 2 Xiaomi Yi Front Panel Replacement, Battery: Schritt 1, Bild 2 von 2
    • Push the battery door switch to the left.
    • Lift the battery door up.
  2. Xiaomi Yi Front Panel Replacement: Schritt 2, Bild 1 von 3 Xiaomi Yi Front Panel Replacement: Schritt 2, Bild 2 von 3 Xiaomi Yi Front Panel Replacement: Schritt 2, Bild 3 von 3
    • Lift the battery tab up.
    • Remove the battery by pulling the removal tab.
  3. Xiaomi Yi Front Panel Replacement, Front Panel: Schritt 3, Bild 1 von 2 Xiaomi Yi Front Panel Replacement, Front Panel: Schritt 3, Bild 2 von 2
    • Introduce the plastic opening tool into any of the sides of the camera.
    • Pry with the plastic opening tool at the seam between the front and the back panel.
  4. Xiaomi Yi Front Panel Replacement: Schritt 4, Bild 1 von 3 Xiaomi Yi Front Panel Replacement: Schritt 4, Bild 2 von 3 Xiaomi Yi Front Panel Replacement: Schritt 4, Bild 3 von 3
    • Slide prying tool along the seam until front panel is fully separated from the back panel.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 15-5, Blackwell Fall 2015 Mitglied von USF Tampa, Team 15-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G5
3 Mitglieder
10 Anleitungen geschrieben
3 Kommentare
Where do you get a spare front panel, the small plastic hooks break easily
ltkipras - Antwort
I would like to know too because i had a crash and i lost the ring that goes around the lens.
fabiocastroam -
For what is the black Strip with the gold plated contact on the front panel? Is that a check for installated front panel, and can i fake them for an replacement panel?
shguro - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 2,825
