Zum Hauptinhalt wechseln
creative ac adapter model maf115160th
Was du brauchst
  1. creative ac adapter model maf115160th, panel: Schritt 1, Bild 1 von 2 creative ac adapter model maf115160th, panel: Schritt 1, Bild 2 von 2
    • panel view
  2. creative ac adapter model maf115160th, inside view: Schritt 2, Bild 1 von 1
    • solder the new thermal fuse (or bridge) between the left and the middle contact (in the picture there is just a bridge -above the red tape-... (had no thermal fuse at hand at first...)
  3. creative ac adapter model maf115160th: Schritt 3, Bild 1 von 1
    • found one 85c in a used li-ion-pack... be VERY careful when soldering NOT to exceed the max. temp meanwhile--- suggest to put a final layer of tape around to get better contact to the coil -where the heat is coming from in case of overload-
Abschluss
close the lid and add eg thermo-glue or just use the soldering-iron and make the housing melt along the pits
8 weitere Nutzer:innen haben diese Anleitung absolviert.
biopilz
465 Reputation
2 Anleitungen geschrieben
3 Kommentare
My A300 speaker adapters has blown I need to get a new one
Sakhile Lloyd - Antwort
Can you show me of this Adapter diagram. The middle line in primary is broken but i don’t know how to connect to which leg
Tien - Antwort
Can I use the lead line instead of fuse to connected
Tien - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 18
Letzte 30 Tage: 81
Insgesamt: 7,706
